I just installed my McG spindles. Not low enough! Now what?
Alrighty.
So I guess my gameplan for now is to install the rear shackles and then decrank the front to match. After that, jack the front end up and trim the bumpstops.
I haven't found a procedure for cranking on the torsion bars. Anything special I need to know?
Thanks for all the advice.
Sweet! Do you guys think with the rear blocks removed, and McG shackles installed I can adjust the front torsion bars enough to match the rear?
The shackles have 2 holes. I assume that one hole is 1 inch down, and 2 holes are 2 inches down. Maybe I should only go down one inch?
I'm really worried that me adjusting the torsion bars is going to make my truck bouncy and handle like crap.
11 sec. Truck Mod
Hey Bud.
This is my Z71 with stock keys decranked all the way and belltech 2'' drop shackles and rear blocks removed.
Im surprised you arent lower with your new spindles, but with decranking the keys you will get about 1.5-2'' lower.
I like to jack the front end up and take pressure off the bolts before i crank or decrank them. Just back them all the way out and let it off the jack, make sure it sits level on each side. Then if your happy get it aligned.
I just ordered a set of McGaughy's 17'' - 2'' drop spindles and rear hangers, im hoping it gets about 2-2.5 '' more of drop.
I wish my truck looked like BLACK04
Plus next week you'll want to go lower anyway!
Mcg spindles and 3/4 ton keys decranked a little. Trimmed bumpstops to just kiss the lca. rides pretty good. The back is now a 1" higher and the fron I cranked back up a little. It was too low for me
