I Need some quick help please
Old 02-27-2011, 12:32 PM
TURBHOE's Avatar
Oh, it's nice and quiet again. Just a off chance bearing pitting. I changed fluid for good measure and see what it looked like. Turns out grease can throw balance way out. Runs smooth again.
Side note: the new cv's don't pop like the old ones under wot!
Old 02-27-2011, 12:38 PM
SincalT/A's Avatar
Warped rotors can cause the steering wheel to shimmy.A temp way to find out for sure is installing some cheap parts store pads.After you put the new pads on it will shimmy real bad on high speed stops.If you leave the pads and old rotors on the shimmy will actually almost go away.The new pads will sorta true up the runout.Im not really reccomending this since rotors are so cheap now but,Ive done it couple times.
Old 02-27-2011, 12:45 PM
TURBHOE's Avatar
Rotors and pads are both new. As in two weeks old. I swapped them out under warranty thinking that was the issue. I hav had a few hard hard stops with them from 80+ to zero with now wobble. A little heat but no wobble.
Otho k she is good to go. It's smooth now beside the little small small vibe from the rear. But the tires were cupped pretty bad from takin too long to rotate. It's very very slight up and down type of vibe.
Old 02-27-2011, 01:27 PM
PT's Slowest Truck
budhayes3's Avatar
Yessir man, grease on the inside of the wheel will definitely affect the balance (as you just found out)...think of the movie "Cousin Vinny"..."You got mud in the tires" lol. We get a lot of folks coming in this time of year complaining about shimmies and vibrations, and the wheels are impacted with snow and ice, same concept as the grease or mud.
Old 02-27-2011, 03:28 PM
TURBHOE's Avatar
Yeah I've had mud and snow and all that makes for a hell of a ride/wobble. I just didn't think grease weighed that much I guess.
drummer0415
11
10-24-2015 08:16 PM
Wrecker 426
10-07-2015 12:11 PM
01silvy
09-26-2015 10:20 PM
2004gibbstruck
09-07-2015 06:05 PM
Quick Reply: I Need some quick help please
