If you say Transmission.....
Old 04-07-2009, 02:42 PM
  #21
Tootall's Avatar
Transmission . . .
Old 04-07-2009, 04:04 PM
  #22
10 Second Truck Club
CurtD's Avatar
Have you called flt?
Old 04-07-2009, 04:09 PM
  #23
Hunt&Fisherator
silver-mod-o's Avatar
my thoughts exactly...
Old 04-07-2009, 04:15 PM
  #24
Where's the Beef?
viciousknid's Avatar
no. I can't see any reason I should other than diagnostics, since I can't afford to ship it. My bank account still hasn't recovered from the refresh.
Old 04-07-2009, 06:14 PM
  #25
GMCtrk's Avatar
I guess this is why they say do a 4l80e swap, it's better in the long run even if it costs more up front. Hopefully, you should be able to find a very cheap 4l60e on craigslist or something and stick that in right now until you can get your built unit back running
Old 04-07-2009, 06:19 PM
  #26
GFYS and STFU
Spoolin's Avatar
Just wanted to mention that there are no bands on a 80E...just an innocent little reminder!
Old 04-07-2009, 06:54 PM
  #27
Where's the Beef?
Little update. I was checking over everything just now cuz i'm really hoping i overlooked something.
Which plug on the neutral switch goes to the cluster? the cluster doesn't seem to be showing what gear i'm in and it I have to get moving a bit before the doors lock. They won't unlock when I put it in park unless I key off and on again.
supposed to lock immediately when i put it in gear.
I checked both plugs and they seem to be in, took them off and put them back on twice.
Old 04-07-2009, 06:58 PM
  #28
GMCtrk's Avatar
they must have changed that. Mine dont lock until I get up to 15 mph.
Old 04-07-2009, 07:22 PM
  #29
Where's the Beef?
The escape I had before this locked at 5mph but this one has always locked when I put it in gear. I'ma let it cool down and the pull the plugs off again cuz it should unlock when I put it in park. And the gear indicator isn't saying what gear I'm in.
I doubt this is causing my shift problems but still needs fixed.
Old 04-07-2009, 08:43 PM
  #30
oldred95's Avatar
Actually mine cost me around 600 bucks to go from a slipping 4L60E to a gear grabbing tire smoking 4L80E.
Are you sure its not grazing the rev limiter? Seems like I could hear that all to familiar fuel cut off, fuel back on, then cut again about half a second before the 1-2 shift. Maybe just try lowering the WOT 1-2 shift and see what it does. It does kind of look like a slide bump though.
Quick Reply: If you say Transmission.....
