If you say Transmission.....
#25
I guess this is why they say do a 4l80e swap, it's better in the long run even if it costs more up front. Hopefully, you should be able to find a very cheap 4l60e on craigslist or something and stick that in right now until you can get your built unit back running
#27
Little update. I was checking over everything just now cuz i'm really hoping i overlooked something.
Which plug on the neutral switch goes to the cluster? the cluster doesn't seem to be showing what gear i'm in and it I have to get moving a bit before the doors lock. They won't unlock when I put it in park unless I key off and on again.
supposed to lock immediately when i put it in gear.
I checked both plugs and they seem to be in, took them off and put them back on twice.
#29
The escape I had before this locked at 5mph but this one has always locked when I put it in gear. I'ma let it cool down and the pull the plugs off again cuz it should unlock when I put it in park. And the gear indicator isn't saying what gear I'm in.
I doubt this is causing my shift problems but still needs fixed.
#30
Are you sure its not grazing the rev limiter? Seems like I could hear that all to familiar fuel cut off, fuel back on, then cut again about half a second before the 1-2 shift. Maybe just try lowering the WOT 1-2 shift and see what it does. It does kind of look like a slide bump though.
