im back... with problems
Hello guys
as i posted a while ago i was havig post 6.0 swap issues, truck wouldnt stop running,
i figured it out, i had a ground disconected, got it running good to go.
filled trans up and ran it through the gears, seamed fine.
Got about a mile down the road and stood on it, WOW it screams and then "pop" smoke everywhere
shut it down in nuetral coasted back into the shop put it on the lift one of the tranny lines on the tranny the top one to be more exact was out of its spot.fluid everywhere.
first off what would happen if i for whatever reason accidentally hooked these up backwards?
Ha this ever happened to someone else.
THANKS for your time
BLAKE
BLAKE
OK good info i had no idea that those clip were not to be re-used,
But can anyone shine some light on what could theoretically happen if the trans lines were hooked up backward, reverse whatever?
I would bypass the radiator all together if you have a separate trans cooler. a friend of mine had a problem with coolant getting into the trans when a small crack developed in his radiator on the trans cooler side.
well how about the fact that i coasted back after i seen i had oil pressure and knew it was the tranny i shut it down in nuetral, about three quarters of a mile from like 75 mph?
can this damage a tranny while it speaws out the fluid?
when i got back in the garge i fired it up imediatly put in gear to attempt to drive it on the lift i heard a friction noise, not much i shut it off and pushed it on to discover the tranny line off.
should i hook it back up and put fluid in it or is game over?
i dont take my truck far but you would be surprised at the heat and humidity we get there in MN, in the summer months when i use my truck.
ive had that happen before.. was doin about 90 and saw all the smoke.. shut her down and hit the side of the road. it sucked. i was on I55 in Louisana on the long bridge
had just enough ATF to get it home thank goodness.
