inner tie rods 05 sierra
Old 10-15-2016 | 10:33 PM
terravast4's Avatar
Default inner tie rods 05 sierra
Im in the middle of front suspension replacement on my 05 sierra 2wd and I'm having a hard time with the inner tie rods. i rented a removal tool from orileys which was a joke and waste of time, i bought a tool from freight harbor and it bent. anybody recommend a a quality tool to get this job done?
Old 10-15-2016 | 10:38 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Haven't looked at one in a while but I believe it has wrench flats. Harbor Freight for a cheap wrench to modify Or large Vise grips.
FWIW, There loctited on
Old 10-15-2016 | 11:12 PM
Wolftrk99's Avatar
I use a large pair of pipe pliers on them when i replace them. They are also sometimes called parrot jaw pliers...
Old 10-15-2016 | 11:48 PM
terravast4's Avatar
has anyone use the " speedy" inner tie rod tool? appears to be the better design
Old 10-15-2016 | 11:52 PM
terravast4's Avatar
yes. it has wrench flats, only two and they are about 1/4" wide but the mount for the upper control arms prevents me from getting a wrench on there properly. the moog replacement is a way better design and would be a snap to get off if it on there.
Old 10-15-2016 | 11:54 PM
Wolftrk99's Avatar
Turn the whes and you should be able to get them broken loose easier
4doorsssilverado
10-16-2023 07:14 PM
redz71truck
10-26-2016 03:35 PM
lycominghunter
10-20-2016 08:39 AM
UV231 Project
10-16-2016 08:51 PM
RELiG
10-11-2016 11:04 PM
