Installed a 2008 4L70E into my 04 and it won't shift and speedo not working
Old 02-16-2012, 04:09 PM
lownslo's Avatar
on the 4l80 swap with two vss sensors you have to add a second vss sensor and pin it at the pcm for it to work correctly. So if the trans has a second vss you might consider doing some reading on the 80 swap and give that a shot. pm me if you want a place to get that rear vss harness.
Old 02-16-2012, 04:49 PM
BANDITSS's Avatar
Originally Posted by TXSZ66AVLANCHE
ALOT can happen with an engine and transmission swap...trust me, I spent a month trying to figure out why my AC compressor would not work sometimes.
I hear you, when we first turned it on, non of the driver side cylinders were firing ended up being 4 clogged injectors
Old 02-16-2012, 05:37 PM
Vince B's Avatar
But this is not an 80. The second sensor in these late model units is whats called a turbine speed sensor. Basically monitoring the input shaft. In this case and with the computer that is being used it is really not an issue. I do agree with what has been said here that the issue is with the VSS not working. I myself would look at the connector to make sure the wires are good. If all looks well I would back probe it with a meter.
Old 02-16-2012, 06:13 PM
BANDITSS's Avatar
How do you back probe
Old 02-16-2012, 07:18 PM
Vince B's Avatar
Use a paper clip to insert into the back of the connector. Then use your meter to check for the pulses the vss sensor creates. Off the top of my head I can not remember what scale to use. Its been a while since I have had to do this.
Jakejack
01-08-2024 10:44 PM
LCHEE
10-24-2020 04:10 PM
1slwgto
08-16-2015 06:40 PM
Mossyoakglock
07-17-2015 08:30 AM
ferrellrooster
07-17-2015 07:07 AM
Quick Reply: Installed a 2008 4L70E into my 04 and it won't shift and speedo not working
