installed converter, now lost 3rd and 4th
#21
could be time for a new trans dude. did you flush all lines and such, and did he iirc twist converter on 3 times until a click? are all harness plugs seated correctly, and everything is bolted correctly.
#23
+1, ya dude u need a rebuild. it sucks i know but that **** just happens, i had a rebuilt 4L60e lasted a yr, there was nothing wrong with the built unit. took a trip out west **** over heated bye bye tranny. not to mention weight kills the 4L60e maybe time to upgrade to a 4L80 dude
#26
Installed a 3200 stall and it will not start to pull until 3k? isnt that normal for a stall converter? Also I might have not read this right, but after the install you drove around the block without the lines hooked up?
#27
no the stall worked for 10 mins tops. Its a used piece. The lines were hooked up, but without a aux tranny cooler. Just contacted some other tranny guys and they are saying i burnt the clutches up. 1 guy can rebuild the entire tranny, and cut and clean the stall for 500 bucks. So I may get him to deal with it. but this other guy still wants to change the fluids 1st. So that will be done in a few hours.
#29
I did, they were close at 1st, but i bent them closer to tranny so had a good 3 inches of space. well, at this point i just hope i could patch it till I get the full rebuild with shiftkit & vette servo. At this point I rather the truck just be down for a while, this is really wasnt the time for it to go.
