Installed DJM 6" flip kit and now pops when first giving throttle
The issue happens from a dead stop it pops real loud if i hit the gas hard. Also if i pull up somewhere and stop and put it in reverse to back up it will pop when i start to move under throttle. It will pop sometimes when turning also.. Im lost at where to even begin now ive tried setting the pinion and even welded the cradles to the axle tubes to lock the angle in.
Is it a 2 piece drive shaft or a 1 piece driveshaft? If it's the 2 piece drive shaft check the center Bering make sure it's tight and did you put a shim kit on the center bearing?
Carrier Bearing Shim Kit By DJM At StylinTrucks.com
