Installing B&M trans cooler
11 Second Truck Club
When Installing the B&M trans cooler will it matter which side is the return line or not I can't see why it would. My truck has the factory cooler so I'm gonna cut the line's and reconnect the new cooler should be fine right?
put the line going from the stock radiator cooler going into the top of the BM and then the return line form the bottom of the BM back into the trans. or else, like said above, the trans temp which may be like 170 or 180 will be heating back up to 190 or 210 by the coolant in the radiator.
Originally Posted by KySilverado
You would want the BM cooler on the down side of the cooler in the radiator otherwise there is possibility of the cooler in the radiator heating up the fluid after the BM cooled it down.
From tranny, to the radiator cooler, to the BM cooler, back to trans.
stallspeed I have the Radix heat exchanger in front of the radiator I want to relocate the trans cooler to the lower valance so it will get more clean air.
spooled I was hopeing I could install this so that both inlet and outlet are pointing upward that is how B&M show's it in there pic's will this be ok.
i dont think it would matter but if i was you i would put the inlet on the drivers side and the outlet on the passeneger side, why you ask? i dont know just me.
Originally Posted by The Breeze
Yeah Ky I will be installing the cooler down by the valance so that the inlet and outlet will be facing upward I will be cutting the factory line's and reconnecting to the cooler does it matter which side of the cooler there conected too I think you all missed understood my question basically the cooler doesnt say inlet or outlet on it so I take it it doesnt matter which side. I understand what you're saying about From tranny, to the radiator cooler, to the BM cooler, back to trans.
my B&M cooler came with instructions that specified that it did not matter the orientation of the cooler itself or which side was inlet and outlet. You have complete flexibility to install it however you like.
1987cut
07-12-2015 09:59 PM
