Isky 212 & Turboed ~ 6psi / What if I DONT put in a stall?
Old 05-31-2012, 02:12 PM
nonnieselman's Avatar
Theres no other stockish converter thats light.
You could see if yank or circle d can do you a light weight tight stall.
Circle D 258mm Pro III 4L80E Torque Converter Triple disck 1B is a 2500 rpm stall
Circle D 245mm Pro III 4L80E Torque Converter Triple Disk 1C is a 3000 rpm stall
I cant get on Yanks site on this computer.
Old 05-31-2012, 02:37 PM
Former Vendor
Circle-D's Avatar
Give me a shout, we have several options that will work well with your combo. You can shoot me an Ask Chris, link in sig...
Chris
Old 05-31-2012, 02:53 PM
seh6183's Avatar
Chris
Filled out the form, appreciate the help.
Old 05-31-2012, 02:56 PM
Chris
Can you throw out some numbers so we can compare the weight difference of the stock 80E TC and some of you Stalls?
Old 05-31-2012, 03:36 PM
seh6183's Avatar
Sorry for my lack of knowledge, but is the stall actually THE converter? What I mean is, can you put a stall on a 80e without removing the stock converter? Or is the replacement of the converter actually what gives it the stall?
Old 05-31-2012, 03:51 PM
your replacing the stock torque converter with an aftermarket torque converter that alot of people call a "stall"
Old 05-31-2012, 03:57 PM
seh6183's Avatar
Gotcha thanks
Old 05-31-2012, 04:02 PM
9 Second Truck Club
stock48's Avatar
Originally Posted by seh6183
Anyway to use another, un-stalled, stockish converter thats a lot lighter? Number one goal is gas mileage, not speed. Or does the big *** 80e NEED a heavy converter?
A heavy converter is not good for gas milage. You want a tight light converter for that.
Old 05-31-2012, 04:39 PM
seh6183's Avatar
Yea I'm working with Chris from circle D to get something that works for me.
Old 05-31-2012, 04:40 PM
seh6183's Avatar
He emailed me back and they have a converter that is half the weight of a stock 80e converter, so 40 pounds. He can only stall it down to 2500 it seems though. Im trying to figure out what the stock 80e "stalls" at from the factory.
Quick Reply: Isky 212 & Turboed ~ 6psi / What if I DONT put in a stall?
