Issues with trans after rebuld?
Just got done rebuilding the 4l60e.....installed w/ new converter....went to test drive and everything worked....after 5 min of test drive 1-2 shift was great, 2-3 shift is great, felt t/c lock up at like 50 mph....so I accelerated and no 4th gear....just like running the truck in 3 instead of OD....what causes this problem...i pulled valve body back off ***** r all in right spots...could it be a electrical issue...i have never had no 4th shift actuation before with 1-2, 2-3, reverse, all working...any idea's?
if it was rebuilt right it has to be an electrical problem. cuz when that happin most of the time your tranny is done.... but if it was built RIGHT double check all connections
LS1TECH & Trucks Sponsor
I would agree on the servo , make sure you do not have excessive clearance, If the PCM is comanding 4th and there is no stuck valve then thats the place to look , on another note pull the servo washer or not, You may be able to see marks where the 4th servo has hit the separator good way to see if this is the case, Good luck
GMCtrk
07-17-2015 06:39 PM
lxcoupe
07-14-2015 10:14 PM
