jerking when slowing down
Engine>Airflow>General Airflow.
Can you list how to get to the table?
I think this could be the cause because my truck was perfect after the tune but later started to do that at certain speeds only.
Mine does this when in gear, but it's a T56. However, the idea may be the same. My tires are basically directly connected to my crank shaft when in gear. Yours are too when your converter is locked. Therefore, it sounds like it may be a converter issue like you may have discovered with the tow/haul button.
Mine didn't buck before the cam, and does every now and then after the cam. It's on decel like you said. Mine does it around 1200-1600 rpms. I believe it can be mended with some tuning.
drummer0415
11
10-24-2015 08:16 PM
whitelazer
09-22-2015 09:38 PM
