Just noticed a slight vibration...
...it's very suttle, and only happens when slowing down to stop around 15-20mph-ish with the brakes applied. It doesn't feel like a brake pulsation, as it doesn't happen at high speed braking and I don't feel it in the brake pedal. I can feel it in the steering wheel...as I mentioned, it doesn't vibrate violently or very pronounced, it's more subtle and has a high frequency (as in the vibrations are close together, kinda like driving over rumble strips, but not as severe). It happens for a second or two then goes away when I hit about 10 mph. It might even be engine vibration transmitting into the cabin since the right side header is very close to the frame and I'm sure makes occasional contact, I'm not sure, I just noticed it the other day and thought about it now and figured I'd throw it out there to see if anyone has any ideas. Doesn't seem to be a big deal, just kinda curious about it now...any ideas?
Bud,
Does it happen all the time at like 20 or 30 MPH? Or is it just as you are decelerating?
I'm wondering maybe about the static balance in your front tire too....
Originally Posted by Torque_Wrench
Bud,
Originally Posted by CHEVRACER83
Check Your Rotors For Runout....
BUd,
It sounds to me like you got some brake chatter in the pads and possibly the rotors too! I talked to 2 of my Techs, and they've both told me to check the pads for chamber and feel the rotor for any high spots. You can probably get this out with turning the rotors and maybe just Emory clothing the pad surface.
What brand of pad and rotor are you running anyway? I ask this because I am having problems with the EBC pads coming in my shop.
BUd,
I'm using Praise Dyno pads and rotors...
Bud, I'd Emory cloth the pad surface real quick and see if it helps. If not, then I'd have a local shop turn the rotors and that should chill it out a bit.
Worst case, you may have some just plain ol' bad rotors. I see it alot here. I've had the best luck with the SD55054R (RH) & SD55054L (LH) from CarQuest. They are a Powersrtop drilled and vented rotor.
I got em on mine and they were only like $65.00 each.
