KENT MOORE TOOLS J TOOLS NEEDED 4l80E REBUILD
I'm curious which of the Kent Moore j tools are absolutely needed for a 4l80e rebuild. these bastards are so expensive it's ridiculous. I know some of these, like the j-8763-02 case holder tool, aren't really necessary. Here is a list of tools from the ATSG manual.
j-38655
j-38789 pump removal tool
j-38358-a forward clutch housing tool
j-38733 direct clutch housing tool
j-38868 main shaft
j-21363 lip seal protector
j-38735-2 re sizer tool
j-35138
j-38729
j-8001
j-38736-2 solid seal installer
j-38736-4 sizer
j-38736-5
j-38736-3
j-38736-1
j-25025-1
j-21368 alignment band
j-38739
j-38693
j-38737
j-21370-10 gauge pin
j-26700-13 dial indicator base magnet
j-23327-1
j-25018-a
j-21362 lip seal protector
j-21409 lip seal protector
j-8001
j-23093
j-38733
j-38732
j-38731-3 spacer
j-38731-2 seal protector
j-38731-1 seal protector
Also is there an alternative tool maker that is cheaper?
Thanks guys
j-38655
j-38868 main shaft
j-35138
j-38729
j-8001
j-38736-4 sizer
j-38736-5
j-38736-3
j-38736-1
j-25025-1
j-38739
j-38693
j-38737
j-23327-1
j-25018-a
j-8001
j-23093
j-38733
j-38732
j-38731-3 spacer
Thanks guys
Custm2500's Rude Friend
Probally the Seal installer and resizer tools are all you really need.
Ebay FTW on those things... Some of them are even New at 1/2 the price. Let me look it all up and i will see If i can put a list together of the things that would be most helpfull.
Maybe some of the builders will throw there 2 cents in.
I know Just enough to get my self introuble...
Here is what the description for each one you listed. I tried to Omit duplicates an correct some part numbers.
j-8763-B case holder tool
j-38655-Holding fixture adapter used with j-8763-B
j-8001-dial indictor set
j-25025-B Dial indictor stand & guide pin set caps
j-38789 -pump removal tool
j-38358-A -forward clutch housing tool
j-38868-A -output shaft assembley remover & installer
j-21363 -lip seal protector
j-35138- universal converter end play checker
j-38729 -over run piston seal protetor
j-21368 -alignment band
j-38693 -oil pump seal installer
j-21370-10 -gauge pin
j-26700-13 -dial indicator base magnet
j-23327 clutch spring compressor
j-25018-A -A/T clutch spring compressor adapter
j-21362 -lip seal protector
j-21409 -lip seal protector
j-23093 -center support alignmet tool
j-38731 -piston seal protector set 3 pieces
j-38732 -forward clutch seal protectors
j-38733-A -direct clutch assembly remover & installer
j-38735 -center support seal installer/sizer
j-38736 -Six piece turbine shaft seal installer/sizer set
j-38737 -band apply pin checking tool. Used with J-21370-10
j-38739 -pump seal installer/sizer
Maybe just look into some of these
j-38734 -Intermediate spring compressor addaptor- Use with j-23327
BTW FWIW GM had 4L80E Service tool kit. This came in a blue crate and came with the main hand tool's to rebuild a 4L80E. I have seen them go for as much as $500 complete on ebay but recently there were 2 kits that sold in the 300-400 range.
Kent moore J-39225 = 4L80E Service tool kit
You should really only need the OD lip seal installers. If you use bonded pistons in the direct and forward you can install them without any tools.
The newer units use sealing rings made of graphite impregnated composite material and no tools needed for those either.
The turbine shaft sealing rings can be installed using electrical tape for a sizer. Universal tool....
I have home made trans holding fixtures that we use, but if only doing one unit you can get by with something less fancy.
How do I change this text
When I bought my service kit I seen one sell for 900 bucks, two weeks later I seen a "buy it now" for 400. I grabbed it....
You will need the apply pin gauge tool as well.
As far a stands alot of guys make there own. You can get clever with a stack of tire's and or a solid trash can. if you want the GM one, they average $100-150 on ebay if your patient. a couple weeks back about 5 poped up around the same time. One was as cheap as $80 But you will need that little adapter for the side of the case and the base to swing it in. The bases are not as easy to find.
