Killed my Yukon Duragrip after a month, carnage pics inside
Old 10-13-2013 | 02:57 PM
TX Tahoe Z71's Avatar
Unhappy Killed my Yukon Duragrip after a month, carnage pics inside
AxisT6 installed a Yukon Duragrip with ARP studs in place of my weak link G80 differential. Ironically, the G80 held up for 5 years behind the blower, but the Yukon only made it one month.
On the way to work on Friday, I made a U turn under the freeway, then went WOT at about 20mph after I had straightened out, had a bit of tire spin, then let off at about 70. Nothing out of the ordinary, but when I turned into my parking garage and hit a speed bump, I head a loud metal on metal clank. I immediately pulled off to the side and looked under the truck, expecting to see a broken suspension park or driveshaft u-joint. Nothing. Decided I shouldn't drive it anymore, so pulled it into an open spot, but when parking, it did a chirp, chirp, chirp, lock and release thing, so pretty much assured me the differential was toast. Had it towed home after work. Opened it up today and found this...
Ring and pinion look good
Old 10-13-2013 | 03:04 PM
Should I go with another Yukon Duragrip (essentially the same as an Eaton Posi), or upgrade to something stronger? A replacement will be under warranty or they will credit me towards another differential. This is my daily driver and not a track machine, so I would rather avoid a Detroit locker or something else not street friendly.
Old 10-13-2013 | 03:17 PM
1994Vmax's Avatar
05 in my sig is my daily driver...... and has a Detroit locker. The truck is stock ride height and just 245/75/16 Goodyear Silent Armors....so not some off roader. Probaby the best traction mod I have ever done. Does it clunk occasionally? Yes. Does it drag the tires a bit in a tight turn.. under throttle it will, no throttle it acts like any other diff. Not to mention it's flat out awesome in the ice and snow wonderland I get 8 months of the year generally.
I have had Auburn LSD's as well as the Eaton clutched units and I will never go back.....
Old 10-13-2013 | 06:36 PM
smokeshow's Avatar
Mod with training wheels
Looks like one of the teeth on the ring gear took damage...or is that just the pic?
Old 10-13-2013 | 06:52 PM
If you're looking at the sparkle in the first picture, it's just a metal shaving and it wiped off.
Old 10-13-2013 | 07:09 PM
TIM Z's Avatar
11 sec. Truck Mod
Wow that sucks man .
As a victim of having ring and pinion trashed along with rear lockers before,
I would try a different unit , that one doesn't like your power or weight , but at least you didn't trash the rear.
Old 10-13-2013 | 07:16 PM
bud8fan's Avatar
does that one have a heat run cycle you have to do like others
Old 10-14-2013 | 10:36 AM
outlawz2004's Avatar
Been beating on mine for 10,000 miles, hope it doesnt kill over anytime soon.
Old 10-14-2013 | 10:48 AM
MASS seller approved
I had a Detroit Locker in one of my trucks with a modded LS2 engine and I absolutely loved it. Gave it a hard beating and never had a single problem. It was a daily driver as well and you would never know it unless under heavy throttle on a tight turn.
Old 10-14-2013 | 03:51 PM
BigKID's Avatar
If for some reason they do not warranty it, you can buy the replacement spider gears and rebuild it. I broke the spiders in my Eaton back in '05 and replaced them with Yukon pieces and it has been great for 40+K miles now. Hopefully you just got a bum one and a new one will last. I am a fan of this style posi unit and wouldn't hesitate to change it out with another one under warranty.
Quick Reply: Killed my Yukon Duragrip after a month, carnage pics inside
