Klunking noise around the tranny
Old 03-17-2010, 12:26 AM
  #21
BuiltNotBought's Avatar
I am not a trans expert but these are just some of things I have come accross. If you just take it apart in assemblies and replaced the damaged parts it should not be to hard... But if your not comfortable doing a transmission I recomend you find a good builder. I would recomend getting a book on it like an ATSG book or a factory manual. I took every last part out just to get an idea what was inside and to get everything clean. I also wanted to check every part inside and out, but I have not gotten around to actually putting one back together
Yeah ive been thinking of buying a ATSG book. Tearing it downs sounds better to me. Then droping the trans while I lay on my back process that has to be done. Think ima buy the book and the monster rebuild kit. And try my hand at rebuilding my own tranny. Only part im worried about is the special tools ill need to do it myself...
Old 03-17-2010, 12:34 AM
  #22
Custm2500's Rude Friend
1FastBrick's Avatar
Best thing you can do is document each part as it comes out. It does matter wich way things go inside. simply putting one of the bearings back wards can cause serious issues.
Old 03-17-2010, 12:37 AM
  #23
1FastBrick's Avatar
Also you might want to look into getting a few special tools to work on it.
Old 03-17-2010, 12:12 PM
  #24
Went to a shop today. They said it sounded like flywheel or tc bolt.
Old 03-17-2010, 04:01 PM
  #25
1FastBrick's Avatar
I dont know the history behind your truck, was the engine or transmission ever removed? What year is your truck and what engine is in it. I have heard of the flywheel cracking on the 6.0's but the 5.3 and 4.8 use a different fly wheel. I have never heard or seen that on one of them.
Old 03-17-2010, 05:21 PM
  #26
Its a just a 4.8 that used to be blown. Im thinking the short time with the blower might have done it or losened the bolts.
Old 03-17-2010, 05:38 PM
  #27
11 Second Hall Moniter
AKlowriderZ71's Avatar
Your noise seems to be crankshaft speed related, and sounds like converter bolts or flexplate. It's easy enough to get a look at the converter bolts, a little harder to see the flexplate bolts. I'd recommend not driving it until it's fixed, surely something is being damaged worse every time you start & run the engine. Just gonna cost you more money by putting it off.
Old 03-17-2010, 07:01 PM
  #28
Yeah pulled the starter and dust plate today. The 2 TC bolts look ok. I cant see the flexplate bolts...
Old 03-17-2010, 07:13 PM
  #29
Should be 3 converter bolts.
Old 03-17-2010, 07:23 PM
  #30
Well hmmm ill double check in the morning. When I counted 2 I was under there in the dark with a flash light. Im sure to see the flex bolts ima have to drop the tranny.
Quick Reply: Klunking noise around the tranny
