launching under boost in 4wd , what drive shafts are you guys using ?
Old 10-18-2016 | 12:44 PM
idahoblkss's Avatar
Question launching under boost in 4wd , what drive shafts are you guys using ?
so im worrying about a couple things and wondering what you 4wd / awd guys are doing for drive shafts and front and rear diffs. are you guys still on stock parts or what have you broke and/or replaced these items and if so with what? sorry been shopping for tires but i have a feeling leaving under boost with stickies something is going to give.
Old 10-18-2016 | 01:05 PM
03sierraslt's Avatar
I have a duramax steel front shaft and a Driveshaft specialists aftermarket rear shaft.
Old 10-18-2016 | 01:08 PM
idahoblkss's Avatar
did you get it because you broke the stocker or just as a precaution ?
Old 10-18-2016 | 01:48 PM
Atomic's Avatar
I have a gauge for that
Both front and rear shafts are special made by DSS in Texas, never had a problem with either. Front diff and tcase are stock, rear is a 14b (never put power through the 10b). Basically if you keep the CVs flat or close to flat youll spin the tires before you break anything. Ive put 1000+ftlbs through slicks on a 200k mile factory CV and oriellys replacement CV without issue. Don't shift the tcase under power either.
Old 10-18-2016 | 01:58 PM
idahoblkss's Avatar
looking at et streets for my 20's but i dont know if its going to snap the shafts.
Old 10-18-2016 | 02:01 PM
Atomic's Avatar
Not if you keep the shafts level and don't try to do big burnouts on pavement in 4wd
Old 10-18-2016 | 02:09 PM
Vortec350ss's Avatar
I always get a little nervous myself...
Others, like Richard, have done it with more power. But it still just seems like a lot of stress.
Old 10-18-2016 | 02:12 PM
Atomic's Avatar
The stock input shaft on the 80e gave up on the 2-3 shift after 4-5 runs on the slicks having survived hundreds of runs on the radials just fine. CVs are good though!
Old 10-18-2016 | 02:34 PM
idahoblkss's Avatar
so you guys upgraded your drive shafts , should i be worried about my stockers? or are they going to hold the power?
Old 10-18-2016 | 02:36 PM
idahoblkss's Avatar
well im awd so i dont have a choice , and no burn outs!!! thats no fun lol.
