LCA ball joints won't come out
I'm getting ready to put my oem LCA's back in w/ McGaughy's spindles. I need to remove the balljoints and I'm having some trouble. I drilled out the rivet heads on one side and tried to knock the rivets thru, but no luck. I used a bfh, then changed to an air chisel w/ a punch on it and no luck. Not even a little. Then I went to work and tried the hydraulic press to press them thru. Still, no luck, and I had to stop as the press was about to deform the LCA. Any ideas? I think I may need to drop them off at a frame shop for removal, but that's mo' money. I welcome your suggestions.
The rivet heads are gone.(good question) I took the arms to work and set them on a drill press. I used a center punch, then a good sharp center drill to start the hole but the odd shape of the arms wouldn't let them lay right and the holes ran off a bit. Anyway, I brought the arms home and used my air chisel to knock off the heads, and switched over to a punch on the chisel to knock them thru. That's when I made a trip back to work to use the press, and now here we are.
oh another thing...try drilling out the full diameter of the rivot with a hand drill taking your time. C clamp the control arm down on a work bench. also if you are good enough drill it out the whole diameter of the rivot and be done with it.
post a pic of the rivots when you can please
