Let's See Your 2 Piece D/S swaps!!
Old 12-25-2012, 08:34 PM
  #21
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by texasglock23
as far as I know only the HD has the longer bed
I never really paid close enough attention on the CC So I wasn't %100 sure.
I only know that there was 3 different beds offered across the truck line up.
Old 12-26-2012, 12:06 PM
  #22
texasglock23's Avatar
Don't quote me on that either...GM always manages to do something we all thought was incorrect or odd.
Old 12-26-2012, 01:10 PM
  #23
blue2003ls's Avatar
Originally Posted by Blown06
If your breaking driveshafts, you either have the wrong parts or the suspension is not set up right. For the life of me, I can see absolutely zero performance benefit changing from 1 to 2. Get the right parts and set it up right.
The factory aluminum driveshaft is only balanced to 3000 rpm and does not give you much warning before it lets go. When I tried to have a custom shaft built, the length was an issue and balancing was a bigger issue. There are no performance benefits between a 1 and 2 piece driveshaft but there is a safety factor if you want to see some track time.
Old 12-27-2012, 12:48 AM
  #24
8 Second Truck Club
Blown06's Avatar
Guess I'm learning.
Old 12-27-2012, 07:28 AM
  #25
Hunt&Fisherator
silver-mod-o's Avatar
Take a spaghetti noodle, hold it by each end and spin it between your fingers, then break it in half, do it again with the shorter piece, which one is more stable? That's all that's going on here. There's greater forces acting on the center portion of the longer shaft, they get exaggerated because the center is farther away from fixed points and allows more flex. The shorter the shaft is, the less this comes into play. The easier it is to balance, and the greater speeds it will withstand. Material does play a role in this too but that's basically why.
TT2005CREW (02-28-2018)
Old 12-27-2012, 03:42 PM
  #26
lglowe's Avatar
I got a spare 2 piece shaft for when I did my 80e swap and all I did was take it to a shop for a yoke change for the 80 and upgraded the u joints to some beefy ones and put it in and adjusted all my angles just right and now that's its been in there for over a year and and i have hit 140ish mph a few times and hasn't had a hiccup.
Have my stock 2 piece ds ill sell locally btw.
Old 12-27-2012, 03:49 PM
  #27
Area47's Avatar
Originally Posted by lglowe
have my stock 2 piece ds ill sell locally btw.
dammit!
Bluecollar Hotrods
06-11-2024 11:37 PM
vmaxpro
08-04-2015 07:02 AM
InsaneDomestics
07-27-2015 02:42 PM
Ketis
07-23-2015 12:37 PM
Mark_k
07-09-2015 12:37 AM
Quick Reply: Let's See Your 2 Piece D/S swaps!!
