lets talk a lil bout air bag suspension
Yes air ride does provide a decent ride but there is alignment issues, if you say there isnt you dont know what you are talking about, bagged trucks have bump steer issues,like it or not you alignment is variable. think about it, the truck goes up and down, its is neer impossible to get it to the exact ride height that the truck was alligned for. just like everything else with the alignment slightly off you get shimmy in the steering, and premature tire wear. Cant help it, it comes with the teritory. the bump steer is also a dirrect effect that bagged truck have it is due to the constant changes in tie rod angle as the suspension moves up and down.
so i set it up at a certin psi, get it alined and i should be good to go. as long as i am at that psi, if i change the hight or psi then my tread will wear differently( in the front right) the psi has nothing to do with tread wear in the back? i think
pressure dont matter in the back, but there is no body in the frikin world that dont like to hit switches while driving it is just too fun. ALIGNMENT yes you get it aligned to a certain psi, mine happens to be about 75, i mean ABOUT!!!! every thing is a factor, a passengers weight thows is off, cargo in the back ect.it is never the exact same. I am confident to say that every bagged truck is going to have premature tire wear.Oh and did i mention that you should look into how much your ball joints are, if you drive a bagged ride year round you will be replacing upper and lower ball joints at least twice a year and that is no joke at all!! ball joint can be a lil pricey too if you cant do em yourself.
u can be 4wd....dragging ur frame ont he ground....put ti in 4wd and continue dragging w/out binding anything.
its been done on an OBS silverado...and its basically the same setup up front.
bag the front off the Upper Control arms
