lifting a 2WD
I just mainly need a little more ground clearance than stock and want a new look for her since its been lowered since a week after I bought it LOL.
spindles, spacers up front
blocks/U bolts (and stock hangers LOL) in the rear...
I've got stock length 2WD shocks all the way around right now. do I need to go to some longer shocks??
Import Moderator
ya the daystar is just the front coil spacer... its the polyurethane ones, don't make as much noise as the aluminum ones.
for the back you could probably even pick up a set of 4wd lift blocks/ubolts then just use 4wd shocks... but that depends on how much you do up front as that will only get you 2" out back, which looks good with 4" up front.
I will do some digging around and get you some pics of some spindled trucks
If I leave the drop hangers and add some 4" blocks out back that should be about right I guess. I'd rather not fight those things anymore haha Easier just to go with a littl emore block to make the difference up.
As far as the front goes, the spindle + spacer should be about what I'm looking for I guess...
any recommendations on tires? not much to choose from in a 33x12.50x17 according to Tirerack. I want something thats much more hwy oriented than off road, I dont even know if I'd go so far as to say an all terrain. NO tire noise etc... the lady will be driving this thing primarily and I want it to be as comfortable as possible ride, road noise etc...
Import Moderator
oh quit being so damn lazy and get them hangers out, you could have them sold on here in a day and have your lift blocks paid for
front = spindle, spacer & shocks most likely
check out 305/65/17s as well as 295/70/17
I left my drop hangers on the 1" drop setting and used a 4" block out back. And from my understanding your front shocks are ok but you need longer for the back. Thats why I bought Z71 rear shocks.
http://dallas.craigslist.org/ndf/pts/1667067045.html
Well after talking to her Ill probably just throw some stock Z71 blocks in the back with stock hangers and do a 2" spacer in the front with stock coils. I wanted to "lift" the damn thing but she's 5'2" and tiny and doesn't want to be crawling in/out of something with the bottom of the door waist high I don't really blame her. Ill probably look at 265/70's or one size bogger. It'll basically sit like a stock Z71. Fine with me I guess...
