light vs. heavy flywheel in a manual trans truck ?
a light flywheel will rev up faster, but will also lose rpm's between shifts. A heavier flywheel is just the opposite, the added weight helps it keep momentum and hold rpm's better during shifts.
IMO, if i had to choose i would go with a lighter flywheel.
Yaw , I kinda figured that. The reason I asked is because I have a t56 trans. and a really heavy clutch and flywheel out of a 06 SSR . The flywheel is a duel mass flywheel and is really heavy. Just trying to figure out if it is better to use the heavy setup or go with a lighter one. I know I would go with lighter in a lighter vehicle.
Thanks Ron
Thanks Ron
Suburban2500
07-19-2015 04:50 PM
grantpo
07-15-2015 12:21 PM
