Line Lock Install on 02 silverado
#21
Yeah you need to flip the solenoid around. You have to run it backwards when installing on the rear brakes or you will run into the issue your having.
I am am still debating on running mine on the front brakes, it seems people are doing it without any ABS issues
#23
Little help
On a 2013. Which line on the master cylinder send pressure to the front wheels. I have seen info on older models which it switches back and forth, depending on year, but can't find any block diagrams for a 2013
I have mine hooked up to the front line, wired up. I can hear the solenoid activate and I get the light for power sent to the solenoid. It doesn't seem to be working properly. I'm not getting any ABS lights so I don't believe the ABS to be causing the issue.
Pretty sure I'm on the wrong line but want confirmation before I start cutting lines again. Thanks for the help.
KyleW707
07-29-2015 09:17 AM
lxcoupe
07-21-2015 03:12 AM
GMCtrk
07-17-2015 07:39 PM
