Loud gear whining after installing 3.90s!
I don't know much about setting up gears. But any mechanic shop or anyone that knows their stuff has always said if the job is done right it shouldn't make any noise and if it does not enough for you to complain about.
for some reason the new pinion bearing wasn't any good, so we reused the factory one and everything is works perfect now, we also found out that the magnet on the differential cover some how came off and got chewed up by the gears and we think this is what started the whole problem, and thanks for the help everyone!
if you chewed up the pinion. . . did you use a new crush sleeve? Sounds like there wasn't enough pre-load.
Bearings are not packed on differentials. You pack wheel bearings only (trailers and older style front wheels). That's what the gear lube is for.
yea we used a new crush sleeve and it was a time getting it crushed, and there was about 5lbs of drag on pinion, the gears looked like they got wore just from the 2 days of him driving on them and they were brand new richmonds from the begining so we took them out and put his 3.42's back in so i think he is gona just sell them now to get some of his money back, im sure someone who has a racecar or something wont mind the whinning.
Sounds like your engagement is off. What did you set it at when shimming the carrier to the pinion?
Did you add the friction modifier agent? That may help some but won't fix true mechanical problems like improper engament.
What type of gear lube did you fillit with?
OOPS, should have read all the posts, looks like you found the issues.
did you break them in properly? Drive 30 min . . cool for 30 min . . . then keep the speed under 55 . . . change the oil after 500 miles?
LCHEE
10-24-2020 05:10 PM
black03rcsb
09-01-2015 11:17 AM
Dezert1500
07-30-2015 03:51 PM
