Lowered 4WD guys
Lowered 4WD guys
How much drop have those of you decranked on stock keys gotten? I'm looking to pull the block and do shackles and was wondering if I could get low enough decranking the stock keys...getting the front level with the rear. I'm at 36" front 38.25 rear. Also, anyone have the part # for the 2WD U-bolts?
Yeah, as kevin said, about 1 1/2" is all your gonna get from the t-bars. I used the 2" drop shackles and left the blocks. probably easier? but now I can do the blocks if I decide to go lower. My t-bars are all the way down, then cranked about 1/2 turn (up) just to preload the key. my front is about 3/4" lower than the rear. remember, You will need to get an alignment if you crank the t-bars.
You can get 2 inches by changing the torsion bar keys.The guy who did my front end alignment said I should not lower the truck by loosening the torsion keys,I lowered mine about 1 1/4 inch by loosening the torsion keys it seemed to cause a bad case of bumpsteer. The keys reclock the torsion bars and are only about $60.
I took the blocks out of the rear and used 2 inch drop shackles. I ended up using Firestone air overload springs. The overload springs give me some adjustment for pulling a heavy trailer, and I put just a little pressure in them which raises the back about 1/2 inch. Without the air bags you will hit the bumpstops hard on the small bumps in the road,this is using 1/2 inch thick bumpstops.
Before
After
Before
After
Originally Posted by bigwreck81
why in the hell would you want to LOWER a 4X4? Just seems stupid to me.
Originally Posted by kbracing96
Why would you want to lift a 2wd? Different strokes for different folks. I only use my 4wd for in the ice and snow in the winter and launch at 10psi of boost on the pavement
PT's Slowest Truck
I got somewhere between 2-3" in the front with Belltech lowering keys and a little de-cranking, and 4" in the rear by removing the lift blocks and installing Belltech 2" drop shackles. I still have the factory length shocks though. The truck actually rides fairly smooth with my winter wheels and tires (Toyo Open Country AT's w/ 275-70 16's), but slams a bit with my Gibbs 20's in the summer (285/50-20). (both set ups are about 31" tall)
