Lowered rcsb 4x4
Hello i have an 06 silverado 4x4 and i dont really use the 4wd so i decranked the keys and used 2" lowering shakles but i want to go a little lower in the back. I want to know how much more can i lower my truck without a cnotch
I actually already removed them sorry i forgot to include that in the post.. So that means i can safely lower just about 1 more inch since i already removed the blocks??
I'd stick your head under the truck and see how far you are away from the bump stop currently.
Figure you can likely only go another 1-2in in the rear before it has a real chance of bottoming out on you. And you won't be able to load much in the bed once you get closer. Also going any lower than what you have done will need drop shocks in the rear. And the pinion angle will change for sure if you go lower, so you'll have to measure that and correct it as needed.
like Trevor said,
if its like the SUV's cut the mounting cup off, smooth it flat, and drill and tap hole in the center for an Energy Suspension pancake style (about 3/4" thick) bump stop.
rijrunr
01-30-2016 10:05 AM
