lowering 07 silverado
I'm kinda enjoying the altitude!!
It's interesting that the belltech catalog does not list the 3" (6403) shackle for the 07's NNBS, yet the 2" (6400) is listed. If you look further back, the NBS trucks use the 6400 and 6403 in same apps so they must be interchangable. I wonder if there is a clearance issue there with the 3" or just an oversight?
One thing I keep asking and never get an answer for (maybe I'm just stupid?): Stock clearance on the front (for my truck anyway) is 5" top of tire to wheelhouse. The wheelhouses on these things basically go straight in horizontally from the fender lip so if you drop it 5" you just lost all your suspension travel. you guys must have good roads... Rear is 8.5" with another 2" up into the wheelhouse so lots of room there...
Also, how much can you drop before needing drop shocks in the rear?
Originally Posted by PSM
How did you get the 20" wheels on the SLE1 interior... I was told you can only get the Z60 package w/20's on SLE2 and SLT?
i ordered both the 6400 and 6403, if the 6403 doesn't work i'll use the 6400 and return the other. i'd like to end up with 2/3 drop
I just noticed my truck seems to have a spacer block between the spring and the axle mounting plate. It measures almost 1.5"! I can see why it would be necessary except for the extra lift. If it could be removed it might be an easy way to get a small drop in the rear. My truck does have the Z60 suspension also, ECSB.
http://www.djmsuspension.com/Product...y/20071500.htm
Looking forward to seeing if the 6403 will work...
iregret
09-10-2015 10:00 PM
cams 98 silverado
07-31-2015 08:36 AM
signguy62
07-27-2015 04:42 PM
