lowering 4x4 tosion key questions
I used lowering keys on my Sierra Denali, and lowering spindles on my 02 sierra. I feel no difference in ride either way. Both my trucks ride really nice for a lowered truck.
I have a 4-6 4wd drop with spindles and decranked keys in the front and shackles and hangers with removed lift blocks out back. Im about to put some 2500 keys in just becuase the front is still about a 1/2" higher. So in short yes you can use 2500 keys, oh and with my keys decranked all the way I feel no difference in the ride quality but hey thats just me.
PT's Slowest Truck
I have Belltech drop keys and have somewhere between 2 to 3 inches drop in the front. The truck rides differently, but I think it's nothing a good set of shocks will cure. It corners much better than it did at the factory height, and the ride is far from bouncy, especially with the 20's on. In the winter when I put in my 16" winter wheels it rides very smooth.
What did you do out back??
I used Belltec lowering keys. Belltec said the keys would lower my truck up to 3 inches by reclocking the torsion bar. After installing the lowering keys I took it to the front end shop for alinement. The front end guy said he could not get more than 1 3/4 inch drop out of it, and still keep the front end within GM specs. You are going to loose ride quality. Taking 2 inches of suspension travel affects the ride. My truck has bumpsteer to the point of almost being dangerous. The ride is a litter more harsh,but I love the look.
In the rearI did 2 inch drop shackle, removed the blocks, and installed 1/2 inch bumpstops. The truck hit the bumpstops hard even over the small bumps.
I had to install firestone overload air bags. Wit 20 psi air in the bags it stopped slamming the bumpstops, and rides smooth in the rear. It did raise the rear 1/2 inch, but I am real happy with the ride in back. I'm saving my money for drop spindles up front to get suspension travel back.
Before
After
Before
After
Before
After
Before
After
In the rear, I removed the oem 2" block and the over load leaf. Then installed a 2" drop shackle and Monroe Sensatrac shocks. I removed the bumpstops and installed some shorter ones from Summit Racing. I also installed air bags, and with 5 psi in them, it never bottoms out.
Originally Posted by npb4me
Well, I dropped my front 3" using keys and it aligned back to within factory specs. I had to trim the bump stops, and I can bounce the front end and I have a good 6-8 inches of travel. I never bottom out over bumps and it still rides like factory with the stock shocks.
That amazing, since a stock height Chevy 4 X 4 doesn't have 8 inches of travel.
I can bounce the front of my truck from the height it is now, up and down 3-4 inches each way. I think a lot of this is because I trimmed the bumpstops.
iregret
09-10-2015 09:00 PM
