Lowering the Z71 this time around
Old 09-30-2009 | 08:07 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Lowering the Z71 this time around
After taking some measurements I cant pull my fifth wheel with the lift I want, and I cant just drive something stock so I think Im going to mildly lower my truck. Remove the lift blocks and maybe go to some hotchkis rear springs, spindles up front and cut the bumpstops some. That should net me a fairly level truck and about a 4/6 drop from stock Z71 height. Im also going to run the hotchkis sways on it, I want this thing to handle like its on rails. I read all different opinions about shocks on here, has anything new come out in the last few months thats better? The 150 per tire versus 450 a tire is also a nice benefit of not driving a lifted truck anymore so I can play more. Im thinking centerline stingray IIIs with 295/45R20s wrapped around them, will I have any trouble clearing those up front? Id like to have as much meat on the ground as possible since I may go play at one of the road course events with it. I know everyone on here has those wheels but I think I may have only seen them once out on the roads in real life so if you dont like my wheel choice, KMA Is there anything else I should consider? Ive never had a lowered vehicle before so this is new territory and I figured its now or never and a hell of a lot cheaper than the lifted route. If it doesnt work out I can always go up.
Old 09-30-2009 | 08:11 PM
dlt76028's Avatar
those 295s will look good. they should fit fine
Old 09-30-2009 | 08:17 PM
JakeBrakeIH's Avatar
heres SBChvy's truck with the same size tire your looking to run...he took out the 4x4 block, 3" shackle and drop keys...
https://www.performancetrucks.net/fo...d.php?t=445612
Old 09-30-2009 | 08:19 PM
1slow01Z71's Avatar
The shocks is the main thing Im concerned about, there are so many choices and ride quality is so subjective. I dont want anything real harsh but I want something thats going to keep the tires planted in the corners. For some reason I have visions of smoking down all four tires going through a turn on a road course in full size truck
Old 09-30-2009 | 08:25 PM
1slow01Z71's Avatar
Thanks, thats the exact look Im going for except maybe an inch lower in the front, I like a little rake.
On a side note it seems hotchkis discontinued their leafs so shackles and those PITA riveted in hangers. Oh well, atleast Ill have some adjustability with the shackle and keys to get my stance right.
Old 09-30-2009 | 08:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
U can't lower a Z71....
Old 09-30-2009 | 10:48 PM
silver-mod-o's Avatar
Hunt&Fisherator
GMracer would be the one to consult for this one Cody.
Old 10-01-2009 | 01:11 AM
BlackGMC's Avatar
Resident Retard
I like my Belltech Street Performance shock. they ride great, Trevert also has them on his truck so you could ask him about them...
Old 10-01-2009 | 01:40 AM
skolman91's Avatar
Ive got belltech nitro drop 2's on mine now, and had them on my last truck, work great imo. plus they sound cool in action
Old 10-01-2009 | 02:02 AM
New keys & cut down the front bump-stops for the front. Remove the blocks & get the longer hangers for the rear. Move the rear bump-stop to the frame(remove u-shaped bracker). Use KYB Monomax shocks to finish it off for a factory ride quality. KYB has part numbers for SSS trucks, those are the ones you want.
