Lq9 and 4l80e. stall or no stall iwth this cam?
the engine is a 2004 LQ9 and teh tranny is a stock 4l80e. should i put a stall in while the engine is on the stand? shoudl i do any tranny mods? this is going in a 1985 c10 that will be for weekend duty and cruising.
cam specs are
@ .050 int. 220 exh 226
gross int .581 exh .584
on a 113 lobe seperation.
cam specs are
cam specs are
cam specs are
You could spend another $700 for a 3000 stall . . .
plan on getting the TransGo HD2 shift kit, with the hardened plate. The 4L80e has a really tall 1st gear
I'm running a 224 230 581 591 -110, it's all stock.
shift kit yes . . . but 80e's don't have servos like the 60e has
Where's the Beef?
a member since 04 and you don't know what a shift kit does? You need to stick around more if you can.
I'd definitely get a shift kit. They are cheap and well worth the cost. A trans cooler would also be a good investment if you run a stall (even if you don't). You can get a good one anywhere from 80-120 bucks.
Are there pics of that camaro on here somewhere?
i have been arounf a while but on ls1tech mostly. and i run a t56. i know what old school chift kits do but this is my 1st electric auto.
thanks for the help. the parts will be on order today.
