LQ9 700r4 swap in a '69 C 10, trans advice needed
Old 01-01-2009 | 02:58 PM
runpasthefence's Avatar
Default LQ9 700r4 swap in a '69 C 10, trans advice needed
Hey guys, I've got an LQ9 on its way to swap out with my 396 in my 1969 C-10 SWB. The 396 was mated to a 700r4 and I planned on reusing it to avoid buying a new drive shaft, shift linkage, etc. However the new motor is drive by wire and has no location to hook up the 700r4 TV cable.
These are my options as I see them:
1: Sell the dbw throttle body and pedal assembly, buy a cable driven throttle body, and buy an LS1 TV cable conversion kit - cost - about $175
2: Convert the 700r4 with a manual valve body - cost $350ish plus install
3: Sell the 396 and 700r4 as a combo, buy a drop out 4L60,65,or 80e, buy new driveshaft and adapt the shift linkage. cost - dependant on sale of motor/trans, but might would break even.
The simplist and most practical is probably option one, but I was pretty set on having DBW. Also, is the time, hassle, and money involved in going with a modern 4l65 or 80 worth the tuneability of the electronic controls?
One more question - does anyone know the differences between the shift linkage hook ups in a modern 4l65 as opposed to a 700r4, would i need to change the truck linkage?
All opinions are welcome, let me know what you think.
Thanks!
Old 01-02-2009 | 12:18 AM
L7 Sierra's Avatar
the 4l60E is the same in most ways as the 700r4 so the driveshaft will work,
The biggest difference is electronic vs standard valve bodies.
ZONES89RS
21
09-24-2015 06:58 PM
Bluecollar Hotrods
07-16-2015 09:52 PM
Aboss
07-09-2015 11:28 AM
Sbrown06
07-09-2015 10:21 AM
