M&H Drag Slicks Q
#31
Originally Posted by BMDMAX
Yours is sweet. Nice and clean. I like the way those BFG tires look too, I would have gone with those but they did not have quite the load rating I needed for the trailer and the tread wear was pretty low. How are they wearing for you?
so far so good. They are rated to handle quite a good load.
The rears may need replacing first though
![Burnout](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_burnout.gif)
#37
No problem. The 4WD Duramax trucks are running 32" tall tires with the 3.73 gears with great results so it should work out to be the same. I like the 30's since it keeps me right at that 3.73 ratio and I certainly don't need a shorter tire with only 3,600 RPMs to spin. I had hoped that the wider Nostalgia being a full slick, softer compound and a taller tire that I could lauch with more boost, hook better and trap at higher speed with the taller tire but I went backwards with them. ![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
I agree that the tire feel is pretty subjective but it was night and day between the two. I did call Tom and he is checking on a few things about when my Nostalgias were built as they have been making steady improvements. I may have an earlier design....
I will keep you posted.
