Manual Control over TC Lockup?
I did this exact mod to my 200R4 on my MonteSS, I just put a toggle switch in line with the brake signal to the PCM which will turn off lock up, and the wire was easy to access. If you can get your hands on a schematic you can probably use a similar wire, or wire in a toggle to one of the lockup solenoid wires going into the trans, as mentioned above.
Hmmmm all good advice. Having the tune adjusted is for later maybe. For now a toggle is what i may do. Just wish someone had already done this and could take the research out of it. haha
just thinking of it the other day..all the roads at home are 35 mph around town and i dont lock until 45...i can go 4 miles at 35 and be unlocked..if i could lock im sure i could save a few mpg and some trans temp every day
If the pcm commands lockup, but it doesn't happen(due to your toggle switch), get ready for a check engine light and probably some sort of 'default' with the transmission commands.
