Manual trans identification help needed? T56 or not?
Old 10-06-2007 | 01:50 PM
IBOHUNT's Avatar
Registered User
Default Manual trans identification help needed? T56 or not?
I have a manual trans that supposedly came out of a 94-97 F-Body. This is supposed to be a six speed however I'd like to confirm that before I drive 4 hrs to go get it.
There is a sticker on the top that reads:
13-86-009
Borg Warner Automotive
61DLF U022051
On a tag on the side is:
12550647 M0742
1386-009 D 37247
Near the shifter as part of the case is
13-86-066-904
Can anybody tell me what this trans is?
5 speed?
6 speed?
The guy told me he can shift it and there seems to be only forward gears. He said this by turning the input shaft and feeling that the output went in the same direction. He asked me if there was a trick to finding reverse. Any help there?
There are also 3 electrical connections
1 on the drivers side near the shifter
1 on the passenger side in the case
1 on the drivers side in the case
Anybody know what each of these is?
I'd appreciate all the help I can get. I have a chance to get this, the clutch, pressure plate, throwout brg, flywheel, pedals, slave cyl, driveshaft for a decent deal if I go pick it up.
Thanks in advance,
Bo
Old 10-06-2007 | 03:23 PM
IBOHUNT's Avatar
Registered User
Thanks!
I take it from the http://www.autogear.net/pdfs/T56_Camaro_2.pdf link that there is a reverse lockout solenoid,E3, up near the shifter handle at the top that needs to be somehow bypassed to get into reverse. Anybody know how to bypass or operate this when swapping it into a truck?
I won't be able to get all of the wiring plugs for the car as it's gone. Anybody help with where to get those?
Old 10-06-2007 | 03:41 PM
nightrunner's Avatar
Mr. Obvious
im pretty sure thats not gonna bolt up to a 99-up gm without some sort of adapter or something, unless you swapped in a gen2/lt1 motor in your truck...
Old 10-06-2007 | 04:29 PM
IBOHUNT's Avatar
Registered User
I have a 94 OBS with a 5.7 (soon to be a 383). It came with the manual 5 speed so I "thought" this wouldn't be a big deal. The hard part for me would be the electronic bits.. (speedo, rev solenoid - if that's what it is near the shifter, backup switch). Fab'ing a cross member or mount or making a driveshaft would be the cake bit.
Anybody that's done this swap and can lend some pointers for the electronic stuff I woudl really appreciate it.
Vash3233
09-22-2019 02:18 PM
ZONES89RS
21
09-24-2015 06:58 PM
Bluecollar Hotrods
07-16-2015 09:52 PM
grantpo
07-15-2015 01:21 PM
Aboss
07-09-2015 11:28 AM
