Manual transmision 4wd to 2wd conversion
I have a chance to buy a 6.0 truck engine mated to a nv4500 trans and transfer case with all related wiring and accessories. I'm wanting to use it in my 47 chevy truck on an s10 frame.
Question: I's there any simple ways like a tail shaft swap that I can do to get rid of the transfer case and just make it a 2wd trans or should I try and swap someone trans that wants to do a 4x4 conversion. Im not waning to build a 4x4 47 chevy.
Woohoo! A fellow Rx7 Swapper. I had a 89 T2 LS1 swap and a 93 LS1 Swap (I'm on Norotors.com too under the same forum name), but I sold them awhile ago.
I don't have a solid answer You might have better luck asking that question over there, but I do believe you can swap out the tailshaft housing, similar to the way the 4l60's can be swapped.
Superman09
09-25-2015 05:55 AM
TAPyvehc93
09-12-2015 08:19 PM
