MH drag radials, how much air??
I just tried 25 psi on the street and I cant flat foot it, but it is a helluva lot better than the hankooks. I will play with it at the track, there will be A LOT of drag cars out, prep is usually badass at Prescott. I just want to be able to flat foot it and not have to lift or get in it gradual.
That converter only feels good now wait till it dead hooks, mine would flash to 4200 and wouldnt move an inch till it got to that rpm and grabed hard. I was able to hook with a 30 ince mt drag radial, I ran 10 psi. If your rim is plenty wide you can get away with more psi but I only had a 8in wide wheel so I had to to get all the rubber to the ground.
