More wear & tear being lifted or lowered? (4WD)
![Question](https://www.performancetrucks.net/forums/images/icons/icon5.gif)
I have a 2002 Z71 ECSB and it presently has a Rough Country Leveling Kit installed on it. This let me raise the front just shy of 2 inches, and the rear, 1 inch. It still rides (and drives) great but did quickly wear out both the idler arm, and the pitman arm, before I installed the Cognito Motorsports support kit.
I have everything, except the shocks, that would allow me to lower it, roughly 3/5".
K2500 Torsion Keys
New u-bolts (so I can remove spacer blocks)
BellTech 2" lowering hangers
Doing the swap is no big deal, and it's mainly just a cosmetic change thing as I get bored rather quickly. I've even considered swapping to lowered during the Summer, and back to lifted during the Winter, since I can't seem to keep a decent alignment, for some reason, anyway.
What's the consensus as far as which setup will be more rough on the truck?
I've read some people saying that lifted trucks suffer in the gas mileage area, but I get 16 or so MPG's in mixed driving, which I don't think is too bad for how I drive.
FWIW, I've also already ditched the 33's as pictured below (in signature), and now have later stock model 17's...so clearance is a non-issue, or at least should be.
K2500 Torsion Keys
I would look into why you can't keep an alignment before anything. Up or down properly installed shouldn't make a huge difference in wear and tear and should keep alignment. You only start running into problems with extreme drops on 4x4s. When I dropped my 99 NBS 4x4 the max every manufactor said was 3" before it starts tearing apart components because of the harsh angles. And all recommend staying away from keys if possible (even though they make and sell them)
GXPJAY
11-05-2015 06:49 AM
wrb002
08-25-2015 03:56 PM
cams 98 silverado
07-31-2015 07:36 AM
