moser girdle/rearend cover, where is everyone getting them??
Old 10-15-2012 | 12:31 AM
  #41
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by PRO TOUR HOE
Its the 10 bolt that came in it but its narrowed 6 inches with a eaton ,373's 31 spline axles c clip eleminators and torino flanges for the brakes and the tahoe weighs 4500 lbs as it sits so it sounds like a good idea I dont do allot of hole shots with but it runs in the high 11's with the road race tires on it and it gets out of the corners pretty hard soI figure it cant hurt
Didn't know you had all that done to it...
You could do a Ford Torino end's with a 9 inch bearings on custom axles in the 14 bolt. There 33 spline.
For the time being the cover might help but you're probably on borrowed time.
Did you weld up the axle tubes on the HOE???
Old 10-15-2012 | 12:39 AM
  #42
PRO TOUR HOE's Avatar
Fearlsss gear in fresno built the rear end and I believe its got ford bearings in it now but I am not positive I figured i would run this one til I break it then build something stronger
Old 10-15-2012 | 12:54 AM
  #43
1FastBrick's Avatar
Not familiar with them.
Sound's like what they did was get custom made axles using ford 9 inch bearings with Torino ends. The 8.5 has a 30 spline carrier. The ford ends and bearings would retain the axles like a c-clip eliminator.
Most axle manufacturers can make them fairly simple. They use a standard 9 inch Axle blank. They drill the bolt pattern, cut them to length and spline them when you order them. Usually a 2-3 day lead time on standard axles. High end racing ones take longer because they have to be heat treated.
Old 10-15-2012 | 01:10 AM
  #44
That sounds like what was done I know the diff goes together like the fords so i guess there is no need for the eleminators DUH ! im a dumb *** , they had the diff for almost 2 weeks and had to wait on axles
Old 10-15-2012 | 01:14 AM
  #45
1FastBrick's Avatar
No harm no Fowel.
I have been told 1 week lead time on axles before only for it to take a little longer.
Strange is good at that as well as Dutchmen.
Old 10-15-2012 | 11:13 PM
  #46
1fastbrick you were right torino ends on the housing with ford bearings and axles splined to fit the chevy
Old 10-16-2012 | 12:20 AM
  #47
1FastBrick's Avatar
I learned me a little bit here and there...
Seriously though, I was actually considering something like this for a C-clip alternative on the 14 bolt 9.5 but the work to get the stock brakes to work was to much hassle. Most people upgrading the brakes and the internals aren't afraid to spend a little more to go the 9 inch route.
Old 10-16-2012 | 12:44 AM
  #48
I was building a 9 inch but it was pointed out to me that a huge company we work with on some of our builds would be very unhappy to see a 9 inch in it and that it might effect future projects
Old 10-16-2012 | 10:17 AM
  #49
Area47's Avatar
lil off topic here, but i would love to find a girdle style cover for the 14 bolt 9.5 in the gmt 900's. so far i have found nil.
Old 11-19-2012 | 05:43 PM
  #50
48548's Avatar
Like this one?
GM Girdles, Chevy 9.5" 14 Bolt Rear End Girdle, TA_1803 | TAPerformance.com
I have a 2012 with the 11.5 and went with this one...
PPE Heavy Duty Rear Aluminum Differential Cover - Raw [138051000] - $329.99 : Pacific Performance Engineering, Innovations in Diesel Performance
