Much closer to the 4WD 4L80E swap!
How do I change this text
I can't remeber, I;ve got to go now, but I posted the lengths in here before if you want to start digging. Other wise I will masure them tomarro when I install the driveshaft safty loop.
Moderately Differentiated
Originally Posted by 4.8T
ok i look and see what i can dig up then. thanks
That # looks short Wilde. GM numbers are usually like 6 or 7 digits right? My invoice is at home otherwise I'd shoot it out there. Looks like FLT can help you out anyways. Good luck with the swap!
FormerVendor
Originally Posted by Wilde Racing
No with the longer 4l80e, I had to get a short rear drive shaft and a longer front.
Does the part number- 19019 Ring a bell for the input shaft, FLT? I found my invoice but I don't think this is the right number.
Chuck
can the driveshafts from a 2500(from 3/4 ton ecsb to 1/2ton ecsb) be swapped over in a 4L80 conversion, eliminating the need for custom lengths? thanks for the part number too, chuck
FormerVendor
Chuck
Rear drive shaft is 66 1/2" long I masured from center of u-joint to center of u- joint.
I feel pretty good about these numbers, because of this post. Click to see
If I can come-up with the same masurement two different times............................
