Much closer to the 4WD 4L80E swap!
#32
Originally Posted by Wilde Racing
All you got to do is swap out this input shaftsun gear and it will bolt right up.
Does the 4l80 shaft fit into the top of that new part. I ordered one and it appears too big to fit into the 4l80. Im thinking that the spline was cut too big. Any thoughts.
#33
How do I change this text
Where did you get your 80e? I know Sean has a machine shop that can machine the tail shaft on the 80e down to fit the 60e transfercase, but other than that I think all 4x4 80e tail shafts are the same. (I might be wrong), you sure it is for a 4x4?
#34
My 80E was off a 2005 Sierra 2500. Im really hoping that it was a problem with machining the spline. Would you know where i can get some dimensions of the tailshaft so I can check for sure.
GrooveCityZ71
08-31-2015 12:05 PM
lycominghunter
07-29-2015 04:24 PM
