My confidence in my 80E is SHAKEN
#21
How do I change this text
Forward clutch for first gear, Forward clutch and Intermediate for second. Does it not down shift into first during acceleration or does it start in second at times?
I'm going to guess lowwer roller clutch....
Roger, I'll trade you trucks... You install a roll pan and paint, I'll rebuild trans....
#22
I picked mine up used with 130,000 miles on it and brownish colored fluid. After bouncing around in the bed for a few weeks when I pulled the pan off I found a similar situation only no big chunks, just lots of clutch debris. What I could see when I put the shift kit in was good healthy looking clutch packs. I had to pull the VB off about 3 weeks later and again there was a lot of crap laying in the bottom of the pan. I haven't had the pan off since but suspect there will be more debris. My thinking was years of normal buildup in the torque converter worked loose when it was laying in the bed of my 99 for those few weeks and is now finding its way back to the pan. My 80E works perfectly though so wherever it came from must not be causing an issue just yet.
#23
9 Second Truck Club
Wild is right looks like maybe pieces of roller clutch to me too. Im hate to talk about mine because then it will blow up the next next time I drive it like the the G80 did. I will say however my kit came with the springs, and we installed them, along with the pump mod. I also changed the sprag, I think it came in the kit but Im not 100% sure.
#24
Oh man, aint that the truth!
Hey Roger, are those chunks magnetic? They don't look to be metal from the pics...at first I thought that it was actually one of the pan magnets broken up into pieces, then I noticed that the chunks had different thicknesses and an almost "rubbery" look to them...
Dude if you were anywhere near close to me we would work the barter system!
#25
Yep, no sprag in the hd-2. I know what you are talking about with the second gear starts. mine did the same thing when the planet gear bearing took a crap in the lower reaction carrier...
It is only a 4,200 mile round trip..
#28
I put he new harness in and buttoned it back up tonight. Until I do something the furthest it's going is in and out of the garage.
These larger parts were laying in the drain pan.
These and the little round bits look like parts to this plate and springs. Direct clutch piston return? Pic borrowed from Blown3qt rebuild thread.
#30
I really have no idea what the chunks are from. Hoping somebody will recognize them but it really doesn't matter. It will be evident when they come out.
