My confidence in my 80E is SHAKEN
Old 06-06-2009, 05:45 PM
  #41
2004SSS's Avatar
time to beef up the backup . or throw the back up in and build the hell out of this one.
Old 06-06-2009, 07:26 PM
  #42
How do I change this text
Wilde Racing's Avatar
Old 06-06-2009, 07:34 PM
  #43
FLT
FormerVendor
FLT's Avatar
By looking at the first pictures in the thread the pieces appear to be rollers and pinion gears that are chewed up. The pictures with the flat pieces I think are from the bearing in the OD planet. I cold be wrong but what do I know. As you said KY you will see it when it comes apart. Vince
Old 06-06-2009, 08:16 PM
  #44
KySilverado's Avatar
^^^"what do I know"
Old 10-08-2009, 02:45 PM
  #45
^^^ nailed it. After months I'm finally tearing into the trans. Will eventually rebuild it. I'll have some pictures up as soon as the battery to my new camera charges up.
Thrust bearing between the overdrive carrier assy and forward clutch assy failed. I probably got it mispositioned when installed the shift kit doing the pump mods.
At minimum going to need a new overdrive planetary set. The needle bearings got into the gears and chewed them up.
I'll need a forward clutch hub. Took some teeth out in it.
Ugly but maybe a testament to the 80e strength. The tranny was still functioning mostly. Really no obvious anything going on.
Old 06-02-2010, 06:26 PM
  #46
LIL SS's Avatar
New found faith then?
Thanks for the warning on the shift kit instal.. Sorry bout the bad luck.
Sorry, drug up an old post during searches
Tydriver
45
10-23-2015 09:19 PM
Wrecker 426
09-30-2015 09:39 PM
mitchellmade
09-27-2015 08:27 PM
OHsixLS3
09-25-2015 04:38 PM
69z-28
09-21-2015 07:31 AM
Quick Reply: My confidence in my 80E is SHAKEN
