My time for Circle D, Give me some insight.
#22
The 245mm doesn't necessarily generate more heat based on size alone, its because they are normally a higher stall speed. The larger diameter converters are "as a rule" moe effiecent (both heat and power wise) because the fins are larger and have more surface area than a smaller diameter converter. If you have a 3200 245mm, and a 3200 258mm they will act very differently and transfer power to the wheels and make heat very differently.
As far as longevity goes, the 258mm or larger will last longer in a single disk configuration purely because of clutch surface area. Bigger cover = bigger clutch = more holding capacity = less slip = longer clutch life. Same basic theory applies to a multi disk setup as well but because of power handling capacity associated with the lockup side of a multi disk converter, its never really too much of an issue (that I've ever seen)
Anyway... Only Chris could really tell you why and how but there's my somewhat halfass educated guess
I like the 258 for the better street manners, and it will run cooler also, although the big trucool seems to handle everyone's trans temp concerns.
Not sure if this makes a difference or not, but since a higher stalled converter soften up the shifts a bit...I wonder if the size of the converter have any effect? Like a smaller converter with the same stall rating as a bigger one softens it up more?
...I decided to re-stall my triple disc a little higher, and since I hadn't run it yet, and wasn't in any major rush, he's re-stalling it for me for free I just had to pay shipping...that's pretty awesome if you ask me
Very cool Derek.
KyleW707
07-29-2015 08:17 AM
lxcoupe
07-14-2015 10:14 PM
Nimoryan
07-05-2015 03:50 PM
