is my tranny gone !?!?!?
formerly 1BADC10 (12/14/2011)
well today is the first time i look under my truck since i towed it home and there is tranny fluid all over the floor!!! i looked for a leak with the truck on but it wasnt squirting out anything. the only think that i found was a wet spot where the driveshaft goes into the tranny. could this still be a possible pump problem and if so about how much does the pump cost, and how hard is the install.
Hmm... if the tailhousing seal is busted then I guess fluid could have spew'd from the rear. Incorrect fluid could = no trans movement in any gear. Drop the pan and see if the filter's where it should be. If so, then lets go back to what you said about the trans having the correct level. Not questioning your intelligence, but did you check level with engine running?
ur trans is toast. My 97 wouldnt go in any gears at all, even reverse. U need to get it rebuilt or a new one sorry homes.
I got a strong suspicion my trans is about 2 kick me in the sack.. and I dont even have all my cam parts squared away.. and this will be 3 in the past yr hah
thanks 1BADC10, yeah when idling i can shift to second and it will roll i shift to 1 first and it feels like i put it in park sometimes it will clunk a little bit but then stop with a small jerk in drive it wont move at all without upping the rev... taking off from second it will shift ok to 3rd, anyway it was dropped off at the shop ....
GOTRS hope ya get your problem solved bro....
I would agree that the most likely cause is pump failure.
On the leaking you mentioned, was it towed home with the rear wheels on the ground? The tailshaft bushing and seals gets lubrication from the front pump. Towing it with the rear wheel on the ground can overheat and burn the tailshaft bushing and everything else inside. The seal likely failed from the heat. Hopefully it wasn't towed that way and the planetaries aren't screwed up from it.
