my truck is uneven?
Old 02-19-2009, 05:09 PM
forbes's Avatar
Default my truck is uneven?
i was lookin at my truck today as it was getting washed... and seems the driver side is lower than the pass.
so i got it home, straightened the wheel on a level surface.... and it seems the driver side is about 1/2 inch lower than the pass side.
i only have 27k on the truck.. it's never been hit.....
what gives?
Old 02-19-2009, 05:36 PM
phasemaster1's Avatar
Famous Chevy lean
Old 02-19-2009, 05:53 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Do you have coil springs or torsion bars in the front?
Old 02-19-2009, 05:54 PM
nlawson6.0's Avatar
is it in the front or back??
did u check tire pressure?
are they aftermarket springs in the front?
-Nate
Old 02-19-2009, 06:42 PM
1quickRST's Avatar
This is very common on these trucks. I had the same thing on my truck. There is a technical bulletin out on this. What chevy does is sell you a small spacer for the driver side rear leafspring and some new u-bolts and this corrects the problem. I did this to my truck and its pretty close to level.
Old 02-19-2009, 06:49 PM
skolman91's Avatar
so what is the problem then? my guess is the gas tank weight? when people go with drops is this still a problem??
Old 02-19-2009, 07:04 PM
forbes's Avatar
im coil in the back....
and i swear last week it was level... at least to the eye...
now i look like 400 lb fat *** driving... with no one in the truck
Old 02-19-2009, 07:18 PM
1quickRST's Avatar
If you are coil in the back, you have the most unique truck on here. Or...you modified it.... You should have leafsprings in the back. Only chevy and gmc SUV's have rear coil spring setups.... take a photo and post it if it really is coil springs cause I would like to see it!
Old 02-19-2009, 07:21 PM
454navyss's Avatar
my truck leans too
and your truck has leafs in the back and coils in the front
Old 02-19-2009, 07:27 PM
1quickRST's Avatar
Chevy in all of their infinite wisdom decided to put the gas tank on the same side as the driver.......
Quick Reply: my truck is uneven?
