My turn for the 4l80e swap
Old 10-02-2012, 06:56 PM
Default My turn for the 4l80e swap
My truck is a 2000 silvy rcsb 4x4 with autotrac. I have a line on a 2000 4l80e from a 6.0 4x4.I need confirmation on some things. First is that the tranny I need and will my autotrac bolt righ up? I need the flex plate from the 6.0 to go with the tranny. I've read that I don't need a spacer with the 99/2000 tranny. I will have to modify the cross member. Where is the cheapest to get a pigtail adapter? I've read that my driveshafts will be fine but will have to upgrade the yolk. I have someone to deal with the tune. Anything else?
Old 10-02-2012, 06:57 PM
03sierraslt's Avatar
Check out the 4L60E-4L80E information in the stickies.
https://www.performancetrucks.net/fo...k-here-460144/
Old 10-02-2012, 07:15 PM
I seen the first page but went on elsewhere. I see his is a ec mine is a rc, I was told that I won't need any playing with the driveshafts. This is the reasoning for my "me" specific questioning as I've read that different people have different setups. Why is he messing with the Transfercase input shaft? Is it necessisary or was it something he wanted?.
Old 10-02-2012, 07:22 PM
You have to swap out the T-Case input gear as the 60E and 80E have different size and # of spline output shafts. As for driveshafts I cannot say for sure but the 80E is longer no matter what configuration, I know I am going to have to shorten my driveshaft on mine when I do the swap shortly as well as get a longer front driveshaft.
Old 10-02-2012, 08:20 PM
What if the tranny came with the t case? If its an autotrac.
Old 10-02-2012, 08:30 PM
If you get a 80E and a transfer case as a combo or a t-case that was on a 80e then no need to swap it, the swap is only if the transfer case was on a 60E.
Old 10-02-2012, 08:42 PM
Gotcha, thanks.
Old 10-03-2012, 11:06 AM
Any clarification on the flex plate spacer?
Old 10-03-2012, 11:27 PM
I got the 80e with the converter. I also got the flexplate that was on the 6.0 that was coupled to the tranny. The flexpate came without te spacer. Since I have all parts, will they bolt up with no problem?
Old 10-04-2012, 11:42 AM
Anyone? I'd like to get started in the install.
Quick Reply: My turn for the 4l80e swap
