My turn for the 4l80e swap
#21
Charlie Murphy!
I'm about to go through with this as well. I'm hoping I can tear into it around Halloween. Now that you've mentioned flexplate something occurred to me.
What years had the longer crankshaft and no flexplate spacer? Mine is a 2000 silverado 5.3L.
I'll be swapping in a 4L80E and NP149 with a SC3000 stall converter. My stall converter has a 3 bolt, bolt pattern. The 5.3L has the 3 bolt pattern as well.
I'm actually planning on swapping in a 6.0L later next year. I'm wondering if my 5.3L flexplate will work on the 6.0. I'm not 100% sure if I have the 3 bolt pattern with spacer or not.
Maybe the longer crank snout was only a 6.0L thing. I'll have to dig through my notes.
EDIT- Disregard what I said. It was the early iron headed 6.0L that had the oddball longer crank. It looks like my 5.3L flexplate will bolt up to my 6.0L.
#22
The 5.3 flex plate will bolt up, but not to the 6.0 converter. The 5.3 converter is a 3 bolt pattern vs the 6.0's 6 bolt. That and the 6.0 pattern is a hair spread out.
#24
I was looking at modifying mu cross member for the tranny but why cant I remove the rubber mount and ad a plate of 3/8 steel as an adapter? That way the cross member don't get cut and all the bolt holes line up. all I would have to do is cut a 5.5x6.5 plate and bolt it to the cross member and then bolt the rubber mount to the plate. I will gusset it from underneith for added strength. All it would do is increase the height by 3/8" but that can be compensated by spacing the cross member lower by that if need be. Also in shortening the driveshaft. Can I just cut off the 2.5" from the hollow splined end?
#27
As for the VSS wiring give Nelson performance a call they have a conversion harness. Your going to need to get your driveshaft shortened not just the yoke. I wouldnt plug the cooler lines because without a cooler, a tranny will get real hot real fast. Unless your only driving a mile or two. If using a stock 80e converter you will need a flex plate off of a 01-06 and you will need the spacer.
#28
