need help 4l60e race trans build
Registered User
hi everybody, I've got a 2000 x-cab with a 4l60e and i need someone with experience building high-performance/racing transmissions. I should have everything needed to do this build... I live in Oklahoma city but would be willing to go a little farther for the right deal. If interested i can send pics and post full parts list. THANKS! By the way this place is amazing! loads of info.
Quick update: found one guy said he do it for 500.00 trans is out...just labor to install my parts high/low? Any thoughts?
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
are you looking for someone or a shop in the area to do the build? Or need help with what parts to buy? If you wanted, you could look into a performabuilt transmission and have a strong 60e
Registered User
I have a patc level 4 kit with late raptor drive kit,torque master kit,5 pinion planents,special 3-4 drum & 8 clutch kit with full thickness steels, billet servos,etc. I also just got my yank sst3200 ls1 converter and hayden 30,000 gvw cooler. I need someone i can trust to put this thing together. Price is a consideration but not a roadblock. By the way i'm trying to build this truck to run in daily driver class hot rods drag week 2011 & will be putting in stroker at tax time.
no reputable trans shop around you to trust or you know? I know a good one in town who will put anything together or install anything i need. Hell he did my converter install, servo, and changed filter/fluid for 400 and I'm 4wd. Im sure someone on here from OK, will have a few names for ya
Registered User
Registered User
Registered User
I sure hope so. This has been more problems than it should be. I have a lot left to do to this truck and everything needs to be done so that i can keep moving forward. By the way, i need upgraded posi or locker no spool... any ideas? 2011 drag week 1000 plus street miles between tracks
