Need help from the manual guys...
I lost the o-ring that goes onto the line that hooks to the clutch master cylinder. I tried calling the dealer but they can only sell me the clutch line and master cylinder which costs $166. Kind of expensive for an o-ring eh?
We've tried a bunch of different size o-rings out of a little o-ring service kit and no luck. I would get a little bit of pedal then the fluid would go past the o-ring. What Im wondering is, is the o-ring a little fatter if you will. Meaning is the ID the same as the o-rings we tried but the OD much bigger.
I was wondering if any of you 5 speed guys or T56 guys remember looking at the o-ring? I took mine out over a year ago and I can't remember. I mean worse comes to worse, I will have to buy the new master cyl and line seeing thats the only thing holding me back from driving it, but I'd rather not.
Any help would be appreciated!
I've been looking over on tech and havnt really found anything yet. One thread had a pic but the pic was gone and the guy was like no wonder why a standard o-ring didnt work. So at any rate, at least I dont feel like a dope for not getting the clutch bled.
I'm pretty sure it's the same seal gm has used since the early 90's. In a last resort, i'd buy a master cyl from the parts store, and return it later....minus the oring of course.
Well found some luck with McLeod. They are called McLeod Quad ring.
Heres a pic...
Ordered 5 of em at $2.50 and some roll pins at .50 cents. Thanks for the pic Gibbs
Heres a pic...
drummer0415
11
10-24-2015 08:16 PM
TAPyvehc93
09-12-2015 08:19 PM
